Has Anyone Had There Ecm Rebuilt?
Old 01-07-2006, 07:38 PM
midiwall's Avatar
Originally Posted by elnido
What I'm starting to notice is the only time the tranny doesn't seem to shift perfectly, is when the CEL is on. When I cancel the CEL with a code reader(I do this about 98% of the time), the tranny shifts real smooth. IS THIS POSSIBLE?
Yes. Is the code still your original PO773?
Does my ECM need to be "reflashed"?
Doubtful.
Looks like time for a tranny cooler as well.
It's possibly the best use of $65 that I can think of, 'specially when you're driving 4500 miles in two weeks to Baja.
Old 01-07-2006, 10:31 PM
elnido's Avatar
Yes, still PO773, just had that solenoid replaced.
Old 01-08-2006, 09:32 AM
midiwall's Avatar
Hmmm... okay, so it's probably a good idea to start looking at the wiring.
When you say that the truck runs better with the CEL cleared, can you expound on how it runs "bad"? You mention "shifting perfectly", so what's "imperfect?
Did you contact the guy that Jamie (MTL_4runner) found?
http://www.race-dezert.com/forum/sho...oto=nextoldest
Did you contact rudestar (bottom of page one of this thread)? Looks like he's got quite a line on ECUs on the cheap.
Old 01-08-2006, 02:57 PM
elnido's Avatar
when the CEL is on, the tranny seems to shift "uncertainly". In other words, it shifts, then shifts back between 3rd and OD. Again, it's really subtle. I can't get it to misbehave on demand. The CEL goes on as soon as I start the truck, everytime. I read the link, different problem than mine. I think I'll try another ECM, as long as I can return it.
thanks
Old 01-08-2006, 06:54 PM
  #25
midiwall's Avatar
Hmmm... okay, given how cheap rudestar is offering them for, the ECU sounds like a plan, though it's a bit of fun to get it out and in (it's up behind the glove box).
Past that though, let's talk a bit more about the symptoms...
Does this happen at all engine/road speeds?
You say the effect is subtle... I just tried something on the way home about this. My engine spins around 1500 RPM in OD at 30 mph. If I turn off OD, I bounce to about 1650 RPM. When this shift thing happens to you, do you see the RPMs come up?
Old 01-09-2006, 04:43 PM
  #26
elnido's Avatar
midiwall, thanks for your help/interest in this. I'll do a couple of tests the next chance I get to give you some more feedback. When I notice the weirdness (subtle) when the CEL is on it's usually accellerating from a start, then suddenly lifting off the gas. I've been digging in the archives about AT/temp also, as I've been seeing my at/temp light lately, on long hills at about 70-75mph.
Old 04-11-2011, 04:37 AM
  #27
jolson's Avatar
Same component - different error
I was about to send the ecu (89661-34140) from my '95 T100 4x4 (220000 miles) to a rebuilder when I came across this thread. My mechanic (AP auto mech instructor - not looking for $$) reported a weak or intermittent signal to one O2 sensor (didn't get the code). The engine is missing - especially when cold. Wondering how to proceed. Rudestar, do you have that model ecu? Willing to part with it?
Thanks in advance.
smilen724
13
11-08-2015 04:11 PM
Ditch Doc
10-27-2015 03:20 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: Has Anyone Had There Ecm Rebuilt?
