91 toyota p/u
You have to jump the t1&e1 terminals in the diagnostic port next to your fuse block. That will step down your idle. At that point you can put a timing light on it and check/adjust it as needed. If you just got the truck. Most people due a tune up. Just don't use Bosch plugs cap or wires. Ngk if your on a budget and denso or Aisin if you can afford it. Also replace the fuel filter.
Hope this helps
Hope this helps
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
