| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE Idle Speed Control Valve Test?
#2 (permalink) |
dunno if its anthing like a supra ISC but this is how you do it for a 7M
when i checked mine the movement is VERY subtle, you almost have to have someone else ground the points while you stare at the part that moves http://www.cygnusx1.net/Supra/Librar...on=FI&Page=107
__________________
Jeremy, 94 4Runner Turbo Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first. |
#3 (permalink) |
Your MAF sensor could be off, dirty, or broken or you could have a vacum leak, or your timing chain could have jumped a tooth if the chain guide is broken, which they usually are. And I have no idea how the ISC valve works, I just turn the screw till the idle is around 800-900 and roll. Good luck,
Mike
__________________
-85 4runner w/ mods. |
#4 (permalink) |
The idle somehow is now at a good level. I fixed it some how. Thanks for your input. Pete
#5 (permalink) |
I'm not having idle speed problems now but I get a miss at 2500rpm. Replaced all tuneup stuff. The O2 sensor voltage is around .19vdc at idle and goes up to .45 at 2500. The O2 also throws a code if left at 2500 rpm for two minutes. Must be lean for some reason. Fixed major vacuum leaks but still low voltage. Any help will be appreciated. Thanks
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| anyone do a writeup on cleaning the IAC (idle air control) valve? | Amir904 | General Vehicle Related Topics (Non Year Related) | 22 | 10-10-2006 08:56 AM |
| cold idle speed adjustment 22re | superjoe83 | 86-95 Trucks & 4Runners | 4 | 01-06-2006 07:49 PM |
| 22re missing at idle, egr valve? help!!!! | punkbek3886 | Maintenance & Repair Archives | 20 | 07-05-2005 05:23 PM |
| 22re thermostatic idle air control | ripcurl | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-28-2004 12:21 AM |
| idle control valve | sskusc | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-26-2003 11:15 AM |
