What can I do to lift the front for cheap
Old 11-16-2009, 06:20 PM
flatyota's Avatar
I have an 84 with SA and im raked just a little towards the front. Im just looking for a cheap way to lift the front a few inches. I was thinking of a shackle but I dont want to throw my pinion angle out of wack. Are there any junkyard leaf spring tricks out there i can do for cheap. Thanks
Old 11-16-2009, 06:22 PM
waskillywabbit's Avatar
Longer rear shackle is probably the easiest and won't mess up your pinion anything noticeable.
Old 11-16-2009, 06:42 PM
elblako91's Avatar
Doesn't a longer rear shackle lift the rear??
Old 11-16-2009, 07:08 PM
Staff
DeathCougar's Avatar
As said by wabbit, it won't mess it up noticeably. if you add 5" shackles, then yes its going to make a big difference. But 1" to 2" shackles will not be a problem.
There is a "cheap" junkyard fix, which is to do a "Rears up front" conversion, or just buy a few leaf packs from the yard and build your own.
4Crawler's Avatar
Longer shackles may give some lift up front:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Easy enough to correct the pinion/caster angle:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
Old 11-17-2009, 11:20 AM
mudinyeri's Avatar
Rears up front (RUF) is about as cheap as you can go to my knowledge. If you're anywhere near Omaha, NE I have a couple sets.
Old 11-17-2009, 07:41 PM
desertcamper67's Avatar
Find a used 2-3 inch lift spring pack. Junk yard or another Yota owner.
Old 11-26-2009, 05:02 PM
84toyota4x4extcab's Avatar
just add a leaf and get your springs crowned
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: What can I do to lift the front for cheap
