Torque specs rotors/steering knuckle
Old 06-15-2012, 08:31 AM
My'lil'truck's Avatar
I've got a 1992 Toyota Hilux 4x4. I'm doing brake pads and rotors. I need to know the torque specs for the wheel bearing hub to rotor bolts (the ones that connect the housing to the rotor. Also, should I use loctite on these. My second question is what is the torque spec for the steering knuckle to control arm? I've seen specs from 125-140 ft lbs. Also, do these need to be put in with loctite? I've cleaned everything and am ready to reassemble.
Thanks,
Jim
Old 06-15-2012, 09:43 AM
rworegon's Avatar
Take a look in the FSM that most closely matches:
http://www.ncttora.com/fsm/index.html
Old 06-15-2012, 04:28 PM
Thanks for the info.
Old 06-15-2012, 08:40 PM
wyoming9's Avatar
Wink
i put Never Seize on those bolts
ladybugRC
458
08-21-2020 10:41 AM
83yotastockR
11
11-10-2015 06:54 AM
Dale Johnston
11
10-31-2015 10:22 PM
Kamaloha
10-16-2015 05:13 PM
Obmi
10-04-2015 11:30 AM
Quick Reply: Torque specs rotors/steering knuckle
