Tire Clearance
Tire Clearance
What's the absolute biggest tires can someone go on a stock (no lift) 4wd extra cab 1985 toylet?
i have a set of 31X10.5X15 Dunlops but before I attempt it I'd rather know first, Thanks
As big as you want with the proper offset and the sawzall mod.
Though, With an AAL in the rear, and front i suppose since you're 85, you could easily fit 33's without problem.
33s will be harder to fit, I had 3.5" lift and 33x9.50s on stock wheels rubbed bad (even w/ trimming):
- http://www.4crawler.com/4x4/4R_suspension.shtml#Epilog
Took a longer front shackle, 1" body lift and moving the axle 3/4" forward to fix that rubbing issue.
on the front anyways... could just have a lift and a bad case of the sags in the rear
foampile
12-18-2022 01:29 PM
djpg2000
11-11-2020 04:56 AM
89fourrunner
02-17-2016 06:52 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
coffey50
07-28-2015 10:55 AM
