Supra afm swap?
Old 11-04-2010, 03:43 PM
Dirtfloorfab's Avatar
Supra afm swap?
Hey I have been researching the 82 supra afm swap so I went out and got on car-part.com And found one part 22250 43110..so what my question is is this a good mod for a basically stock truck all I have are ngk iridium plugs acold air intake in the works with battery afm swap? Any help is appreciated
Old 11-04-2010, 05:09 PM
myyota's Avatar
Yes, its a good mod for a mostly stock engine. You will notice better throttle response and a little more power going up hills. It would also help if you added a header and exhaust.
Old 11-04-2010, 05:21 PM
BigBluePile's Avatar
Yes. Theres about...well...more than ONE thread about the sweetness that is the Supra AFM swap.
Old 11-05-2010, 07:36 AM
irab88's Avatar
yep. and don't forget that search feature
Old 11-05-2010, 09:07 AM
i did search to find the part numbers and stuff but most of the people that i seen on the threads with this swap had more aftermarket mods and such on there motors dont get me wrong i plan to do a header and exhuast when wallet allows but i dont think im ever gunna put a hotter cam in my motor or port and pollish i think ill go diesel before that on that note what is a good cheap header? ive heard lc engineering is good and what do these motors react to better 4 to 1 or tri y's
Old 11-05-2010, 09:10 AM
irab88's Avatar
yeah, the supra afm is plug-n-play
Old 11-05-2010, 10:18 AM
It wasn't that I was wondering if it would work well with a mostly stock truck
Old 11-05-2010, 11:39 AM
kiyobrown's Avatar
Ok, MINE IS A STOCK MOTOR!!
I have 197k on the ticker. I added an LCE header almost a year later. Plug and play, and noticed better throttle response and held speeds going up hills better. Its not a magical makeover for the 22re, but for the 50 bucks everything cost me, it was worth it.
I looked into a tri Y header, but went with a 4 - 1. works fine.
Old 11-05-2010, 02:08 PM
olharleyman's Avatar
Yes but high dollar ,you can find as good a header for cheaper right now I keep hearing good stuff about the OBX on ebay might be worth checking into before dropping all that money on LCE. I have there Pro Street Head and if I had done a little looking around I would have done a engnbldr head same set up for half the price just sayin look before you leap
Old 11-05-2010, 02:37 PM
ChefYota4x4's Avatar
Love my LCE 4-1 Cali header.(Few pages in on my build thread in sig, whole exhaust system, pics, etc.) I know they're not cheap, but for just the header with studs and gasket..... 199$ Is that really that bad? 300$ for the whole kit with pipe to CAT and O2 Flange and wiring kit, etc. EASY install... just a lil haggling with the bracket and a heat shield coming off.. nothing major. I got the full kit, as you'll see if you look into it.
Still looking for an 82 Supra AFM....... someone is snatching them all up from under me! GRRR, lol. Jk... Doing suspension first.
Happy Hunting, Dirtfloorfab,
Mark
Old 11-05-2010, 03:05 PM
I actually found one check out car-part.com they have quiet a few ranging in price from around 50 to high dollar in michigan there isn't a whole lot of pick and pull yards and even less with foreign parts hope that helps ya man
Old 11-05-2010, 04:15 PM
Thanks, Dirtfloor! Yeah, I found one, locally, it's listed as 82-85 Supra, then the number, and it seems to be the same number that I remember for all of those.
Anyway, I'm still trying to figure out ball joints, lol.............it's a long list, seemingly never ending! hahaha.
Mark
RatOmeter
10-22-2015 03:17 PM
mtb_taco
10-05-2015 04:36 PM
crashburnoveride
08-28-2015 09:20 PM
Sidherish
08-02-2015 01:42 PM
TransAmBandit
07-28-2015 11:30 PM
Quick Reply: Supra afm swap?
