soooo i need help: new to me 1988 Truck
Old 04-03-2013, 06:00 PM
Levi Huff's Avatar
Levi's 19884x4 pickup build-up
soo i have a 1988 toyota 4x4 pickup and honestly ive fallen in love with this truck it shifts nice drives geat and i love it but want to build it up and have no idea at all where to start. right now imlookinfor 63 inc chevy springs to put on and im buildin removable speacker boxes to put behind my seat. after that i have no idea where to go from there any ideas??? this is the first build ive ever done and im tryin to learn parts and pieces new to all of this.
Here is my truck....
Last edited by Levi Huff; 04-05-2013 at 05:22 PM. Reason: fit guidlines for build-up section
Old 04-03-2013, 08:11 PM
Co_94_PU's Avatar
#1, locate and replace the missing splash/rock guard under the radiator fan. Will cut down on the "My engine just vomitted under my hood" look.
#2, remove clean treat and plasti kote/dip the battery hold down.
#3, remove the header clips(grill) and see if you can get them back into the header panel(grill). the little nub ends should lock into the square holes. the hood and bumper generally hold this in place but you can zip tie or wire tie it to keep it from rattleing
#4, you lack power steering, should be a relativly easy retro fit if you can find a donor vehicle at the salvage yard (Yeah took me abit to find anything "wrong" in that photo )
#5 Sliding rear window looks like it might be a bit leaky, not much you can do with that apart from replacing what looks like torn moldings. Give it a good silicone lube and it'll slide like new.
Nice clean headliner, Rarr! and a 60/40 seat those are plenty cush' compared to the flat bench.
Could do for good ole cleaning. and maybe a new seatbelt "motor", retracting themby hand helps fight the spring wear. (Going to have to add checking mine for gunk to my list, thanks for the reminder)
Whats the "goodies" on the floor doesn't look like it'll fit, just toss those on my lawn with your mud flaps next time you're on I-70 in eastern CO
I'm a resoration guy if you can't tell by the list. Here is the 4x4 version.
Clean treat and seal the fender rust before it gets out of hand, spend a little bit on bumpers and sliders and start saving fr the 4x4 goodies if you're headed that direction.
PS. Read the rules sticky and edit the title on your first post to comply (Edit post, advanced, and you get access to the title again).
PPS, As cool as a mud covered rig looks keep it clean and all the drain holes clear and it'll keepthe rust at bay. Nice clean looking truck!
Old 04-03-2013, 08:20 PM
YotaInSC's Avatar
Good find on the truck! After you get done with all the preventive maint. and the necessities, what you want out of the truck is really up to you. I'm a new member here and I've learned a lot, mostly before I finally joined.
Old 04-03-2013, 11:27 PM
wyoming9's Avatar
Red face
Welcome to the forum !!
Spend a hour or so reading threads on here every day .
Should give you some understanding learn the basics of Toyota`s before thinking you need to do this or that to keep up with the neighbors.
Make sure the brakes and the drivetrain are all in the best of shape.
Old 04-04-2013, 12:15 AM
uncleblues's Avatar
flush your brake lines, and flush them good. My experience with this era vehicals (I'm on my fourth) is this needs to be done to keep your brake lines healthy and rust free. Get a quart of Dot 3, fill the MC, open the bleeders one at a time and pump until the clean stuff comes out.
Old 04-04-2013, 12:20 AM
pcola's Avatar
congrats on the new yota! I also have a 88 single cab 4x4 and i agree with the whole power steering thing, its a must because im sure you will want more tire soon but just saying welcome and if ya need anything or have a ? just hit me up ive learned so much from this site o and there is a yota graveyard 10 min away from me so if ya cant find something he has it lol! anyways have fun and be safe
p.s just my op. 22r/re and high rpm's = is a big NO NO
Old 04-05-2013, 04:59 PM
Levi Huff's Avatar
thanks for the advice all im startin on preventive maint. tomorrow. ive been havin a problem with my throttle sticking it is extremely annoying soimopening the throttle body to clean it and see if there is and gunk stuck around the butterfly valve. just soyou all know imnew to everything so a lot of abbriviations i dont knnow imtryin to tech myself mechanics and sofar i get a lot of dumbass looks from people and stuff cuz i dont really know this stuff or what im doin so i mayask alot of questions i appreciate any help though
Old 04-05-2013, 05:34 PM
Levi Huff's Avatar
how do i move this back to build-up thread?
Old 04-06-2013, 01:21 AM
wyoming9's Avatar
Red face
Just start a build thread then link to this one
6th Gear
19
12-10-2019 07:31 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
WI Girl
06-25-2015 03:45 AM
data
08-17-2002 11:50 PM
Quick Reply: soooo i need help: new to me 1988 Truck
