shocks location "85 pickup"
Old 07-28-2009, 01:22 AM
RMP8080's Avatar
the picture is what I want to do, question is with a 6 inch suspension what size shocks. Has any one do this....
thanks.
Old 07-28-2009, 07:09 AM
desertcamper67's Avatar
check out 4crawlers info page. lots of information you will use on this and other projects
Old 07-28-2009, 07:43 AM
scuba's Avatar
First of all the pic pictured is wayyyy off, With the ammount of shock shaft showing, that leaves NO room for any uptravel, If you get a shock that long your going to need to go a lot higher (IE, Into the bed) if you dont want to mess up your shocks every time you wheel, If you even wheel.
Second. You need to measure the compressed and droop distance of the mounts from eye to eye, its not just a what size thing..
Old 07-28-2009, 08:01 AM
4Crawler's Avatar
Detailed writeup with photos and measurements below:
- http://www.4crawler.com/4x4/4R_suspe...shtml#R-Shocks
Old 07-28-2009, 04:13 PM
FredTJ's Avatar
And, that's about the worst shock placement that you can do.
Look at outboarding the shocks.
That makes a huge difference.
Fred
Old 07-28-2009, 04:18 PM
scuba's Avatar
Fred actually that really depends. Triangulating them can lead to increased travel out of the same shock then if it was 90* or close to.
Although, when they aren't 90* or close like stock it really takes away from the dampening effect of the shocks. On a dd I wouldn't do it..
Old 07-28-2009, 04:22 PM
FredTJ's Avatar
I wouldn't do it on a DD or trail rig. Really lose a lot of body roll control.
Outboarding the shocks is a much better idea and if you do it correctly you can get a long shock to fit well.
Fred
Old 07-30-2009, 12:11 AM
RMP8080's Avatar
-http://www.4crawler.com/4x4/4R_suspe...shtml#R-Shocks
thanks, to all, great information
Hopefully this will work well on my truck.
Old 07-30-2009, 02:55 PM
Scuba, I think this is what you should do with your new Bils. A little off angle to soften up your ride a little and get all the flex you should be getting.
sphealy
09-03-2015 07:55 PM
mistershmi
08-31-2015 03:44 PM
punks_is_4x4
08-21-2015 01:35 PM
terminator
07-27-2015 07:13 PM
akaphilly
07-09-2015 02:34 PM
Quick Reply: shocks location "85 pickup"
