Rear Prop Shaft Oil Seal (Remove T-Case housing???)
Old 03-22-2012, 03:41 PM
_RaStA_RoCkEt_'s Avatar
Hello,
This little project is giving me a headache!
Does anyone know if in order to replace the seal on the T-Case (the one behind the companion flange for the rear prop shaft) I need to REMOVE the Extension Housing of the Transfer case? This would include the Speedo Cable Sensor/Gear and such.
My real question is, besides having to buy a gasket for this, will any transfer case parts leap out at me when I pull this case section? If so, is there a better way to pull the seal without removing the section of the case?
I can't think of a way to pull this seal while the Splines of the rear output shaft block my access... and I'm at an impasse! Does anyone have insight?!
Pictures bellow:
(all T-Case housing bolts except 2 taken out of Extension housing, Speedo Gear loosely fitted)
(Whole rear t-case, for perspective)
(Close up on problem seal)
Any help is SO appreciated, especially since rain is coming tomorrow!
Old 03-22-2012, 03:42 PM
PS: I ain't budgin' till I get a 2nd opinion on this... I love my t-case tooo much to mess it up!
Old 03-22-2012, 04:05 PM
James Woods's Avatar
Nope, no need to remove anything but the seal, then you need a big socket or pipe to drive the new seal in.
They make a seal puller that will do it, might be able to get it out with a screwdriver.
Old 03-22-2012, 04:32 PM
rworegon's Avatar
Pick one of these up at O'Reillys, NAPA, etc.....
http://www.youtube.com/watch?v=BtsGU2nLrJg
Old 03-22-2012, 04:35 PM
Gratzi all!
I pulled it and replaced with a national / federal mogul seal... now to re-torque!
Beers on me at margaritaville in SC if you ever make it down!
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
85run
07-08-2015 11:20 PM
cchinny
06-25-2015 08:11 PM
abalagtas
06-22-2015 12:57 PM
Quick Reply: Rear Prop Shaft Oil Seal (Remove T-Case housing???)
