Rear Prop Shaft Oil Seal (Remove T-Case housing???)
Hello,
This little project is giving me a headache!:fire: Does anyone know if in order to replace the seal on the T-Case (the one behind the companion flange for the rear prop shaft) I need to REMOVE the Extension Housing of the Transfer case? This would include the Speedo Cable Sensor/Gear and such. My real question is, besides having to buy a gasket for this, will any transfer case parts leap out at me when I pull this case section? If so, is there a better way to pull the seal without removing the section of the case? I can't think of a way to pull this seal while the Splines of the rear output shaft block my access... and I'm at an impasse! Does anyone have insight?! Pictures bellow: http://i23.photobucket.com/albums/b3...h/DSC00682.jpg (all T-Case housing bolts except 2 taken out of Extension housing, Speedo Gear loosely fitted) http://i23.photobucket.com/albums/b3...h/DSC00683.jpg (Whole rear t-case, for perspective) http://i23.photobucket.com/albums/b3...h/DSC00684.jpg (Close up on problem seal) Any help is SO appreciated, especially since rain is coming tomorrow!:fire2: |
PS: I ain't budgin' till I get a 2nd opinion on this... I love my t-case tooo much to mess it up!
Nope, no need to remove anything but the seal, then you need a big socket or pipe to drive the new seal in.
They make a seal puller that will do it, might be able to get it out with a screwdriver. |
Pick one of these up at O'Reillys, NAPA, etc.....
http://www.youtube.com/watch?v=BtsGU2nLrJg |
Gratzi all!
I pulled it and replaced with a national / federal mogul seal... now to re-torque! Beers on me at margaritaville in SC if you ever make it down! |
