NEWB Twin stick?
NEWB Twin stick?
Ok sorry in advance cause this has probably been dicussed to death on here already but here it is anyway. I'm honestley not at all a newb to wheelin and building rigs but never knew anyone around who had a twin tcase setup. Does this setup independantly controll fr and Rr gear selection for the tcase gearing so you have more crawling selection of gears or what? IDK cause I never messed with one or had someone explain its function to me.
Twin stick allows separation between 2wd and 4wd function. Dual cases allows a normal gear reduction and a secondary reduction thru the second case and the transfer is done thru the second case.. It essentially adds a SUPER low gear set. Thus why you have two shifters with dual cases. Much better to differentiate control between easy to severe crawling terrain.
TheBFA
02-15-2020 06:55 AM
primordialbeast117
12-19-2015 12:23 PM
myotherrideisayoshi
09-29-2015 05:41 AM
