Looping idle when on the brakes
Old 10-14-2007, 01:21 PM
KegKiller's Avatar
Hey all, I've got a 93 pickup 22re 5spd 14xxxx. Was running great until about a week ago. Whenever I'm on the brakes and idling in traffic, the idle revs up then drops back down. I don't have a tach, so I'm not sure the range, I've had to turn the idle screw all the way in or it idles very high. Any help appreciated
Old 10-14-2007, 07:07 PM
mtnfreak's Avatar
Bet you've got an air leak between the MAF or AFM and the throttle body. Check that out first. 2nd guess would be an air leak in one of the vacuum hoses coming off the intake chamber.
Old 10-14-2007, 07:28 PM
4Crawler's Avatar
You ridle speed is likely set too high. For more details, see the web page baloe (2nd Q&A on the page):
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Old 10-14-2007, 08:00 PM
KegKiller's Avatar
What's the best way to find the leak. I've heard something about waving an open propane tank to listen for an idle increase? The idle screw is all the way in so I cant lower it anymore.
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
CanRunner
07-20-2015 01:29 PM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Looping idle when on the brakes
