Headers
Ahh dude that header is bad ass. I'm running the TriY myself and I love you. You made a wise choice man. Let me know the power difference. I've had mind now since about 2008 I believe and I've only had to repair it once. When I lost my driveshaft at 70 MPH it flew around and it my exhaust breaking the weld on my header were the Y is closest to the block. I just pulled it off and welded it up...
Check with Doug Thorley directly... I ordered mine thru Summit.. There was an issue with one of the welds being to thick and it caused a leak.. I had to grind it down..
When I figured out what was making the header leak (at the cold air pump inlet ports) I called Doug Thorley first.. I was told there are 6 different headers for the 22R /22RE.
I was also told I could not put the engine that is in my truck, in my truck... Its working pretty good tho....LOL
TheBFA
02-15-2020 06:55 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
DiggnDeep
09-03-2015 02:45 PM
