Head Removal on a 22re engine ???
Old 06-03-2010, 04:47 PM
John Deer Yota's Avatar
I need help on removal of my head on my toyota 22re.
Do i need to use a wedge on the tensiner to keep it from moving when i dissamble chain and sprocket from cam ? does the tensior operate off of oil pressure or sprring pressure? and i need the correct torgue specs.on head bolts , including the small one and also the cam shaft sprocket bolt ?
Thanks for any help . please email me @ luv2foxhunt71@yahoo with any help Thanks again.
James
Old 07-02-2010, 09:57 PM
Lawn Dart's Avatar
I wouldn't worry too much about the tensioner. I'd worry about the two head bolts between the number 1 & 2 and 3 & 4 exhaust ports. They almost always snap.
Old 07-03-2010, 06:56 AM
swampfox's Avatar
if you are not installing a new timing chain, you need to wire the timing chain and the cam gear to gather . it will help keep it in time.
Old 07-03-2010, 07:34 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Email sent.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
God's Bounty Hunter
07-08-2015 12:54 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Head Removal on a 22re engine ???
