Build Your Own Junkyard Double Case?
and to answer your question, i wouls show up with 600 cash and see what he says..... Those 5.0 gears have gotten a somewhat bad rep for being weak..... but idk what the truth is in that?
I'm not sure if there is a corelation or not, but I've had great success. Never lost a shaft to anything other than lack of maintenence (let a joint run dry from a torn boot. When it broke, I looked in there, and there was more dirt then grease. Personally I don't count that one, but thats up for interpretation I guess. However, that was before duals).
The IFS is a system like anything else, and has its strengths and weaknesses like everything else. I can see why mud would cause you all sorts of problems, as from what I've seen, mud is not something that can be crawled.
Also, wheeling in rocks and rock racing are very different animals. The big dollar trucks with the strongest parts on the market, that are usually seen in the vids are hammering down.
I very rarely see anything above 1000-1200 RPM's when I'm driving over obstacles, even larger stuff:
And a vid of the same obstacle, which, while clearly shows how poorly I can select a line sometimes, also is representative of my normal throttle usage and speed.
http://www.youtube.com/watch?v=d2rR3waQ2A0
#26
well you got me there.... i seem to bea little more throttle happy.....
And i wasnt saying i crawl through mud. I was sayinng was even breaking shafts in the mud when i still had ifs.
#28
My point was just that its more likely that you would break in the mud, because in order to get through mud, people have to gas it!
My point was that I think it'd be more likely that people would break shafts in the mud than in the rocks. With dual cases and dual lockers, my lines through the rocks are usually very slow and very controlled. I don't drive in my ever, but I've seen videos of those who do, and they are always on the throttle hard.
I've noticed that a lot more people in the south east and north west have issues with IFS more so than those of us in the arid west.
#29
i see what you are saying, but i really dont agree that rocks are easier on parts than mud. sure heavier throttle is used in the mud because there is next to no traction.... its hard to break something when not given traction.... that being said, rocks are much more fun!
#31
1 Post
Oh and has anyone had a auto transmission with double cases. Any pro or cons? I'm debating on switching the 1uz from the stock auto transmission to the stock 4Runner 5spd transmission. It's exspensive. So just weighing the pros and cons of both.
#32
Most people I've seen with an auto either run a single 4.7 case or two stock 2.28 dual cases. Something about the torque converter makes the gearing feel way lower than it actually is. You can search for more info on that and find a bunch of stuff. Check out Dirtco's 4runner build, he's running an auto and a single 4.7 case.
#33
1 Post
And I will check out his build thread thanks.
theking11863
03-19-2016 09:36 PM
Crgrey42
08-10-2015 04:23 AM
priest16
15
08-06-2015 07:43 AM
