ball joint spacers?
Old 11-30-2009, 06:19 PM
94t4r's Avatar
ball joint spacers?
Does anyone know if these limit flex?
I have my torsion bars turned now and i have the worst flex ever so I wanna add these as well to give it that extra lift.
Old 11-30-2009, 06:41 PM
MaK92-4RnR's Avatar
you can put these on and relax your torsion bars for better ride quality. it'll give you that extra lift too.
Teuf's Avatar
AH Willkommen.............Its the loss of droop, that screws up flex.BJS and crank will not help. what size tires do you have? Spend money on lockers and keep susp near stock. hat year truck> More info.
Old 11-30-2009, 06:43 PM
Teuf's Avatar
Yes that too, bjs and lower to stock height, plush ride.
Old 11-30-2009, 07:19 PM
4Crawler's Avatar
Ball joint spacers will increase the flex given the torsion bars are set soft enough to allow for the full travel. Why? They increase the vertical separation between the bump stocks on the control arm and the contact points:
- http://www.4crawler.com/4x4/ForSale/...er.shtml#FAQ10
Old 11-30-2009, 11:07 PM
94t4r's Avatar
im runnin 31x10.50. im not concerned with the ride quality on the street, i just want some more flex, im a single father so money isnt easy thats why i was lookin into these bj spacers, so by relaxin the t bars a little, i will get a little more movement?
Old 12-01-2009, 01:51 AM
crawyota's Avatar
Location: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
Hey Teuf, is you s/n short for TEUFEL (devil) ???
Old 12-01-2009, 07:06 AM
4Crawler's Avatar
Yes, the spacers will give you some lift so you can turn the torsion bars back down to retain your current ride height and with the relaxed bar, the suspension is softer and can move easier.
Old 12-01-2009, 10:51 PM
94t4r's Avatar
thanks guys, they are ordered and should be here thursday. anyone know the napa numbers for some shocks that will work with this new addition?
Old 12-02-2009, 06:36 AM
4Crawler's Avatar
Some shock part numbers below:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ1
Old 12-02-2009, 07:18 PM
Blue Bowtie's Avatar
Sorry to thread jack, but I have a question. I had my torsion bars cranked to over level, not on bumpstops though, anyway, when I got an alignment, they guy had to decrank the bars to even get close. When I realized this, I asked him to stop, and align it as close as he could. Well it's better than it was, but it's not what it should be. Anyway, my question is, can buy a 1" BJS, and decrank my torsion bars quite a bit so that they can align my front end(camber) perfectly, or as close as possible.
Thanks
Old 12-02-2009, 07:55 PM
4Crawler's Avatar
Probably depends on what the cause of the alignment problem was. If you have some damage up front to where the adjusting cams are at their limits at stock height, then any sort of lift over that may push them past their limit. If the alignment issue was simply the guy not knowing what he was doing, then the spacers or torsion bar lift would be no different as far as alignment goes. Might try a different shop and see if you get the same results.
Old 12-04-2009, 09:09 AM
Alright, thanks for the info man.
Old 12-05-2009, 09:51 PM
94t4r's Avatar
I got the bjs installed, but it was hell. My driver side shock bolt was stripped, and my cv boot tore, but other than that i love it. Any other things i schould do now? As far as suspension goes
Old 12-05-2009, 10:01 PM
Teuf's Avatar
Did you fix the boot before you buttoned her up?
Old 12-06-2009, 08:22 AM
94t4r's Avatar
I dont have the money to do it till next pay day
Old 12-06-2009, 12:19 PM
94t4r's Avatar
Would it be a good idea to get a panhard drop bracket? What about some manual hubs?
Old 12-06-2009, 12:31 PM
camo31_10.50's Avatar
well a panhard drop bracket is for the rear.....idk why you would want one if you didnt do anything to the rear???
manual hubs will prolong the life of your hubs and decrease the rotating mass under your truck..thus "in theory" you should net a bit more (very small amount) of pep and gas mileage increase lol
Old 12-06-2009, 08:19 PM
94t4r's Avatar
I wanna do the manual hubs, what all do I need to do that? Will some manual hubs off of an older axle swap right in? The rear has an lc coil swap, so its lifted approx 4 inches
Old 12-06-2009, 11:35 PM
4Crawler's Avatar
Manual hubs off another IFS equipped pickup or 4Runner will work.
Quick Reply: ball joint spacers?
