back up (reverse) lights - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-21-2005, 12:33 PM   #1 (permalink)
token7888's Avatar
Has anyone ever installed additional back up (reverse) lights? Any tips?
I need to back up into a dark and narrow garage area and the factory lights are a little inadequate when the weather is bad. I think that I should be able to splice a relay into the factory back up light positive lead and then run a power wire from the battery to the back of the truck to power the light. Or maybe get power from my hitch cable. Any potential problems with this?
Thanks in advance for any help.
J
__________________
'92 4Runner SR5 3.0 Auto 4wd
token7888 is offline
Old 12-21-2005, 12:38 PM   #2 (permalink)
cootees's Avatar
Send a message via AIM to cootees
There are many threads about this. A lot of people have done it using fog lights, ect.. Do a search and you can find lots of good information.
__________________
-- '90 4Runner 2Dr
3.0 / sas /OME 860 coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust
cootees is offline
Old 12-21-2005, 12:58 PM   #3 (permalink)
celica's Avatar
I used to have tractor lights on the back of mine but they didn't last very long in the snow, rain, backing the seadoos into the lake. I ended up putting an extra light attached to my garage door opener. My mom put up a motion light in her garage.
__________________
Matt
2003 4-Runner Limited - Couldn't stay away from the runner
2003 Sequoia Limited
1989 Supra Turbo
1992 4r, 5spd V6 Sold
celica is offline
Old 12-21-2005, 01:08 PM   #4 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Moved to newbie section.
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 12-21-2005, 02:08 PM   #5 (permalink)
4Crawler's Avatar
One thing you might try is swapping in a white 1156 LED bulb for the stock bulbs. I but a set of narrow beam, 30-LED white bulbs in my '85 and it is a huge improvement in light output. The main problem with the stock lamps is the reflector, if you want to call it that. It is more a light scattering device than a beam focuser. The LEDs don't rely on a refflector and the narrow beam version puts almost all the light out straight behind you.
But yes, add a relay and separate lights if you want. I'll be doing this on my truck, with a 3-way switch, mainly for off-road use. Switch positions will be down for automatic activation from the reverse light switch, center will be off and up will be manual on for lighting up at camp or vehicle repairs, etc. on the trail.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-21-2005, 02:25 PM   #6 (permalink)
celica's Avatar
this won't work for his truck. He has a runner with the 912 bulb as a backup light in the tailgate.
__________________
Matt
1989 Supra Turbo
celica is offline
Old 12-21-2005, 02:35 PM   #7 (permalink)
token7888's Avatar
thanks
Yep, found 64 hits in the overall "SUV and Truck Tech" section versus the 4 threads I found in the "86-95" section. Thanks for everyones help. Now to do some reading...
J
__________________
Old 12-21-2005, 03:02 PM   #8 (permalink)
4Crawler's Avatar
OK, did not know the bulbs changed with the 2nd gen backup lights. Learn something every day. Assuming a 921-style bulb, they only go up to a 9 LED version, so that probably would not be that bright.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Reverse lights not working? NEED HELP eyeseeyou 95.5-2004 Tacomas & 96-2002 4Runners 6 05-04-2009 10:53 PM
No reverse lights on 91 Fo by Fo General Electrical & Lighting Related Topics 4 05-30-2006 10:57 AM
Reverse lights work but not when in reverse Dekri Maintenance & Repair Archives 4 06-23-2005 04:35 AM
aux. reverse lights doink 95.5-2004 Tacomas & 96-2002 4Runners 2 06-02-2003 04:28 PM
No reverse lights.... seafarinman 95.5-2004 Tacomas & 96-2002 4Runners 6 02-26-2003 10:15 AM
2009 InternetBrands, Inc.
