Aternator and voltage regulator replaced but battery STILL does not charge?
Old 05-24-2008, 03:00 PM
greenie's Avatar
Question Aternator and voltage regulator replaced but battery STILL does not charge?
Well, the title says it all. I have replaced the voltage regulator which tested bad, and replaced the alternator which tested good, and the battery which tested good. The engine stays running with the battery disconnected, and the battery does not recieve a charge while the truck is running. When jumped, the truck stays running but will not restart under its own power when turned off and i attempt to restart it.
what should i do? Should i just push it down a mineshaft?
any suggestions are highly appreciated. im BAFFLED at this point.
Old 05-24-2008, 03:20 PM
4Crawler's Avatar
Measure the voltage at the alternator when the engine is running. Then measure at the battery. If not equal, then check for continuity in the wiring between the two.
Old 11-25-2008, 04:18 PM
Canadian_Grizz's Avatar
Did you resolve this problem???? I just got an 83 toy that's having the same problem. New battery and alternator, but still won't charge. Sorry for bringing this thread back to life but I need help!!!!
Old 11-26-2008, 06:43 AM
absoface78's Avatar
Good call, I have an '84 PU pretty much the same thing. I changed the battery and alternator. The truck is old and the wiring on the plug portion and the ground were mashed and frayed(most of the copper was broken). I just shook the wires around until I got continuity. Just temporary, I'll re wire when I get home from deployment.
Doug4320
03-24-2018 10:11 PM
Johntom240
7
07-13-2015 12:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Aternator and voltage regulator replaced but battery STILL does not charge?
