91 P/U LOUD creaking/popping in front when turning, CAN'T FIGURE OUT!!
I have a 91 Pickup DLX and every time I cut the wheel in either direction there is a very loud popping and groaning coming from somewhere in the front end. I have checked all the moving areas and I can't find any rub spots. I also greased and lubed EVERYTHING and still have the issue
Any suggestions are welcomed
The part circled in yellow hits the crecent shape.
You can grease them everyonce in a while, or get new rubber end caps from the stealership.
There are 4 stops total, make sure you get them all.
Its understandable, the yotatech search sucks. What i do is go through google. For example type in "noise when turning yotatech" and it will almost always bring up a yotatech thread about it.
read toyotanation faq must read in the 89-95 forum, the faq on these trucks here and the toyota bible on pirate and after a few hours you can go from asking questions to answering and knowing what will be going to on your truck in what order an x amount of miles.
CV's?
Have a 2000 4Runner and I am having getting a quick pop/knock sound (and feel in the wheel) whenever I turn to the right past about 50% (and moving forward). After reading up here, my hunch is that it is the CV joint and not the steering stop (I had that issue with a toyota I owned a long time ago and this sounds different). Is there any easy way to determine if the CV joint is bad without taking it to a mechanic to diagnose?
Isaac
Isaac
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
