1988 22re 4 runner
Old 10-07-2010, 06:04 AM
jlj
jlj's Avatar
1988 22re 4 runner
i have a 1988 4 runner with the 22re and i want to put a 1995 22re motor in it. what do i have to change
Old 10-07-2010, 06:24 AM
hilandfrog's Avatar
I think some of the plugs for some electrical parts and possible the computer?
some chatter going around about MAFs having different resistance for some years???
Someone smart should be along soon to lay it out?
Repo
Old 10-07-2010, 06:44 AM
snobdds's Avatar
ECU
Wire Harness
Fuel Injectors
AFM (These trucks don't have MAF)
Old 10-07-2010, 07:01 AM
xxxtreme22r's Avatar
as long as you change out the sensors from the 1988 motor to the 1995 motor you will not have to change out the wiring harness at all nor the computers. the mechanical parts of the motor are exactly the same.
Old 10-07-2010, 08:15 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
everything...
Everything but the physical engines. Hows that for simplicity?
I'd make it easy and just swap intakes and exhausts.
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1988 22re 4 runner
