upper ball joints
Old 07-21-2008, 08:06 PM
DIHOWARD's Avatar
upper ball joints
tore the rubber boots on the upper ball joints installing leveling kit.
looks like 4th gen ball joints are welded into the UCA. does anyone know if the boot is replacable?
Old 07-21-2008, 08:37 PM
highridinyota's Avatar
most likely a uca replacement is in order.check with dealer for boots.if not avail.replace uca before you have that alignment done.almost a positive no on boots though
Old 07-26-2008, 03:51 PM
DIHOWARD's Avatar
boot replacement
the boots are replacable by themselves. the parts guy at Toyota had to check twice but found them. they are 15.00 per side. comes with grease!
Old 07-26-2008, 04:28 PM
corax's Avatar
you might also be able to find "universal" ball joint boots through the aftermarket, but there's no telling how well they'll fit and last. If they are available through Toyota, it's best to go that route
Old 07-26-2008, 06:19 PM
jason191918's Avatar
Are they really welded on?
Old 04-06-2011, 01:48 PM
fluke's Avatar
Boot's,Dang.I did the same to my lowers pretty much the same way.Lift spacers.Been worried bad for a few days $$$$$.Hope they have them for the bottoms too.
Old 04-06-2011, 02:02 PM
MudHippy's Avatar
Yes, as a matter of fact, they do.
OEM part # in yellow.
43345D COVER, LOWER BALL JOINT DUST, RH
43345-69025 2002.08-2005.08 GRN21#, UZN21#
43345E COVER, LOWER BALL JOINT DUST, LH
Old 04-06-2011, 02:10 PM
fluke's Avatar
Thank you MudHippy you made my week.
Old 07-22-2011, 08:14 AM
92foreruner's Avatar
Sorry to hijack but if I need new ball joints in my 03 4R do I need new Control Arms? Has anyone replaced the joints only. I know my 92 you could just replace the ball joints
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: upper ball joints
