off set rims or spacers
Old Jan 26, 2008 | 02:14 PM
jim s's Avatar
i have 07 tacoma i just put the 2.5 level ket on on the front end. iam told that i have to put pro comp alloy wheels for the back space to get the space (for the tire chains)
or spacers what is better? i need to put real tire chains on the front axel.
can any body help me
jim
Old Jan 26, 2008 | 08:24 PM
ddc_5114's Avatar
never use spacers!!While many have used them, it is not a good thing to do. you will exert more stress to your wheel studs, suspension, etc.....best case scenario, your ride worsens. i.e. vibrations....worst case your wheel falls off and you pile into the civic in the oncoming lane slaughtering a family of four. Pro comp cannot be the only brand of wheel that will give you the correct offset. Check w/your local tire/wheel dealer. (not a dealer that only sells pro comp)
Old Jan 26, 2008 | 08:26 PM
ozziesironmanoffroad's Avatar
spacers are ok just dont go crazy with em. i personally wouldnt reccomend any spacer thicker than 1.5". to be safe tho go with the offset wheel. if you do use a spacer, just make sure that you put new wheel studs on. and yes with them you will notice your wheel bearings going out more often, your ball joints failing more often, etc. for every action there is an opposite action.
Old Jan 28, 2008 | 09:13 AM
jim s's Avatar
thanks
jim
Old Jan 28, 2008 | 09:14 AM
jim s's Avatar
thank you
jim
chukarhunt
Dec 8, 2019 11:39 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Yotoder865
Jul 9, 2015 07:51 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
