| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
will a 22r flywheel work on a 22re ?
__________________
1989 4x4 regular cab, 22re/5-speed, Tacoma wheels/10:50's |
#2 (permalink) |
yes.. and who said the clutches are different.
__________________
Dan 95 4runner 3vze A/T 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd |
#3 (permalink) |
the part #'s are different (figured it may be the throw out bearing being different)....... my nephew bought a rebuilt 22re and he said his pressure plate wouldnt bolt up to the flywheel. we had figured his maybe someone had installed a 22r engine in his truck before he got a hold of it. so he took his flywheel/clutch and bolted it up to the new engine but i didnt know if the weight/balance was the same.
highway
__________________
#4 (permalink) |
20r 22r 22re flywheels between 79-95 are basically the same and are interchangeable .
later years they went to a larger clutch dic surface , but flywheels are the same .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
#5 (permalink) |
There is some sort of part number difference in the later 22re's - I think it was a change in spring design, but they should fit.
22RTE flywheels and clutches are different from 22R/22RE - I see a lot of jacked up non-OEM parts numbers that list 22R/22RE/22RTE as the same parts.
__________________
http://www.22REturbo.net |
#6 (permalink) |
as far as i know the only thing that changed between 22r and 22re was the fuel delivery, one being carbed the other injected. so it should be fine
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust 120amp Mr. Alternator rear lockrite, optima yellow top xrc8 winch & AOR bumper coming soon my bikes: 1980 Honda CX500-1997 honda cbr F3 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RTE clutch/flywheel in 22RE setup???? | Yoda | General Vehicle Related Topics (Non Year Related) | 8 | 04-12-2009 07:28 PM |
| 82 4spd on an 86 22r...will it work? | jriebe | 86-95 Trucks & 4Runners | 0 | 05-27-2007 04:55 PM |
| 22re flywheel torque specs? | Dr.Feelgood | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-11-2005 10:05 PM |
| 22re Flywheel resurface - Step height? | CrazyDiamond | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-16-2005 01:54 PM |
