Where can i buy a the fuel line can't get at autozone?
ok i made a dumb mistake when i pulled my 22re out of my pickup the other day i though i had everything unhooked and i began lifting my fuel line snapped now i cant find a place that has then autozone doesnt sell then?? any info?
My autozone carries straight sections of fuel line with the fittings already on each end. Measure the piece you broke, and buy the closest length. You'll need a tubing bender, but having the fittings pre-fitted helps a lot. Making the double-taper fitting you need from raw tubing is not easy.
every fitting size and pitch under the moon.
If Autozone cant get it go to Napa like said above they can get certain thing
that other auto part stores cant dream of LOL
Been there done that on my 3VZ-E......had to get it at the dealer.
Are you talking about the little rubber hoses off of the fuel pressure regulator? If so, they sell that at autozone as efi fuel hose. If you are talking about the hard lines that attach to your regulator you need to go to the dealer.
09-04-2015 09:27 AM
