| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
whats the stock gearing on an 86 runner?
#2 (permalink) |
Go with 4.88s for a manual, and 5.29s for an auto, there is a door jam # that will tell you your stock ratio, if not there is.............the test.
__________________
4.3/5.0 Do iT!
#4 (permalink) |
I have 4.56's on 33x12.5's and think they are perfect. Honestly I think alot of people overgear here. I plan to keep the 4.56's with 36's and change them out to 4.88's if its too sluggish. I don't blame people for overgearing though stock 22re's and 3.0's are really lacking in power but I dont need my daily driver to be a screamer...
__________________
87 Chevy- Flatbed, dana 44 lockright, Custom 10.5 14 bolt lockright, 36 TSL radials |
#5 (permalink) |
So's you get that answer read here, then check the VIN.
http://toyota.off-road.com/toyota/ar....jsp?id=274535
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! |
#6 (permalink) |
with my truck 4.10s and stock 28s, i could roll 90 down the freeway, with extra power, and climb hills in 5th downshifting to 4th on occasion. And 5.29s will put me close to that with the 35s, if im correct it will actually be a little too low but i figure with the weight increase in the tires/rims it will be damn close.
__________________
4.3/5.0 Do iT!
#7 (permalink) |
anyone have a price range on changing gears?
#8 (permalink) |
depends, you figure its about 500 just for the gears and install kits, and if you drop your diffs and take it to a shop its like 100-300 per diff, if you take in your whole truck its like 1000-2000 depending on who does it. i have a buddy that does gear install with lockers for 100.
__________________
4.3/5.0 Do iT!
#9 (permalink) |
i wouldnt even change gears if your gana run 33s...i have stock gears and 35s and have no problems no reason for 5:29 gears on 33s
__________________
1990 Yota, 3.0, 5sp, std cab, 4" pro-comp susp lift, 3" body lift, 35" Pro-comp XTerrains, flowmaster exhaust, Grenade shifter ! Allways dirty. |
#10 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
He has a smaller motor, though.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#11 (permalink) |
It's reccomended you do 4.88's for 33's . I'm going to run 5.29's and 33's this summer.
I have a Richmond Gear 4.88 Ring n Pinion 7.5 (IFS front) set for $85 shipped. You're gonna pay around $200 any ring n pinion set. TG has 8" sets for around $130 IIRC. Marlin has Yukon 7.5's for around $185 iirc.. http://www.yotatech.com/showthread.php?t=112540 =)
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#12 (permalink) |
oh and you probably have 4.10's with a 22re manual.
__________________
#13 (permalink) | |
Staff
Wow that is the only the 4th time this week I've seen this question answered
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000 Need Toyota Parts? www.davezoffroadperformance.com Quote:
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 86 Runner Stock suspension>>35 inch tires | gixxer_grand | 86-95 Trucks & 4Runners | 5 | 03-12-2007 11:20 PM |
| Whats a good stock 89-94 runner bumper worth? | halfshaft5@aol.com | The Classifieds GraveYard | 8 | 02-24-2006 08:37 PM |
| Has anyone ran 35's with stock gearing? | YeloSub7 | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 09-29-2005 02:28 PM |
| Stock gearing?? | 4unner4life | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-01-2005 06:01 PM |
| Gears & re-gearing(what is stock)?? | Stump1883 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 08-12-2003 05:52 PM |
