what is this part?
Old Oct 7, 2010 | 03:35 AM
nate9915's Avatar
what is this part?
what is this orange piece in the hose? my truck is missing this and the hose is just taped togther from the PO
Old Oct 7, 2010 | 03:40 AM
dropzone's Avatar
Fossilized
it should show up on the vacuum diagram on the hood stickers,
if not you can download the FSM using the link in my signature
Old Oct 7, 2010 | 03:46 AM
92 TOY's Avatar
looks like part #23285A VALVE,CHECK,NO. 1 (see pic below)
I could be wrong too, but this site has pics and diagrams, just punch in your details.----->>>> http://www.toyotapartszone.com/Page_...y=%2811=USA%29
And also, get the FSM like Robb says.
Old Oct 7, 2010 | 03:49 AM
nate9915's Avatar
does anyone know if running with out this part could hurt any thing?
Old Oct 7, 2010 | 03:54 AM
92 TOY's Avatar
personally, I do not.
I believe it's a $6 part, if I remember reading that right.
Old Oct 7, 2010 | 04:07 AM
nate9915's Avatar
ok thanks
Old Oct 7, 2010 | 04:35 AM
iselloil's Avatar
Its a one way valve. Air can only travel in one direction with this in place.
Old Oct 7, 2010 | 04:50 AM
xxxtreme22r's Avatar
It's there for a reason. Most likely because it would be bad if air would travel in the wrong direction because it would cause a vacuum leak or something. I am probably wrong with what it does on that motor, but I am not wrong in saying its there for a reason. Please do not remove stuff off your motor without knowing why its there and what it does and what it affects.
And yes it's a one way check valve.
Old Oct 7, 2010 | 05:20 AM
nate9915's Avatar
Thumbs up
i didnt remove it. it was missing when i bought the truck. The picture is of another truck and i was wondering why i didnt have that check valve so i am ordering one to put in the place of the black tape thanks everyone for the help
Old Oct 7, 2010 | 05:52 AM
4Crawler's Avatar
Looks like that check valve sits between the intake and the ADD switching valves. Probably functions similar to the check valve in the brake booster line. That one is there to only allow engine vacuum to pull air out of the device (increasing the internal vacuum) and not allow that vacuum to drop when the engine vacuum drops, like when you mash the throttle down. Without that valve, you might find your front axle disconnecting and dropping you back into 2WD just when you hit the gas to get out of the mud pit.
Old Oct 7, 2010 | 05:57 AM
thank you 4crawler, so yes, I don't see how that not being there would end well at all.
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
