What flamethrower injectors are better?
Old 07-03-2014, 12:59 PM
cpljenkins01's Avatar
I have a flamethrower coil on mine with e3 plugs and it does good.
Old 07-03-2014, 01:07 PM
Thehollywood811's Avatar
Wait... flamethrower makes coils too??
Old 07-03-2014, 01:36 PM
I don't know if they made it or not but that's what its called.
Old 07-03-2014, 01:55 PM
Oh that looks like a good alternative too, where did you put the plug from wiring harness that plugs into the original coil? Not the wire that goes to the distributor cap but the other one?
Old 07-03-2014, 02:00 PM
  #25
I cut it off and put male and female connections on them so I can just plug the old one in if I need to.
Old 07-03-2014, 02:05 PM
  #26
Old 07-03-2014, 02:20 PM
  #27
That's a good idea! I still don't really see where you connect the wires to once the oem coil is gone? Because the plug on the old coil that the wires connected to is non existent on the new coil? Therefor they have nothing to connect to?
Old 07-03-2014, 02:21 PM
  #28
Or do they splice into the red and black wires coming from the top of the new coil in the pic?
Old 07-03-2014, 02:27 PM
  #29
Yea there is two wires off the oem coil one is ground one is + and you just splice them and put connectors on them.
Old 07-03-2014, 02:40 PM
  #30
Okay yeah Its obvious now looking at the picture lol where'd you get the coil from?
Old 07-03-2014, 02:47 PM
  #31
Ordered of Amazon I believe it was under 40 bucks
Old 07-03-2014, 02:57 PM
  #32
Cool man thanks for the info!
Old 07-03-2014, 03:12 PM
  #33
No problem. Just got some ordering the injectors. The yellow ones. Are they as noisy as the stock injectors? Mine you can hear them ticking
Old 07-03-2014, 03:29 PM
  #34
Yeah I think they are a bit quieter, mine wernt to bad before but they had almost 235K miles on them lol but the plastic covering is supposed to make them less noisy
Old 07-03-2014, 03:37 PM
  #35
Ok cool thanks.
Old 07-18-2014, 08:11 PM
  #36
Injectors in running good. Very happy so far.
Old 07-19-2014, 01:52 AM
  #37
Punchy's Avatar
I am running the grey FT injectors, The ECU will adjust to them quickly, But during open loop they would dump a lot of fuel pegging my AF gauge (An adverse affect to the fuel gauge).
Things are good after adjusting the AFM 6 clicks lean.
My only complaint, More of an observation since I don't care, Is they are really loud, There is no insulator between the injectors and the fuel rails.
Had two other Toy owners thought I had loud cam clicking and had to explain.
Old 07-19-2014, 01:57 AM
  #38
Glad you like them man!
Old 09-27-2014, 06:44 PM
  #39
Hey man finally got my 7mge afm and put it in and my truck idled super super low and was about to die and I could never really get it to idle up.. and if I tried to give it gas it just bogged and didn't like it... I played with the bypass air screw on the afm that you have to drill out and also my idle speed screw on my throttle body and there was no change. I tried it at 5 6 and 7 clicks rich and not much changed. I'm at 14 degrees advanced timing also.. just thought I'd ask before I started a new thread
Old 09-27-2014, 07:00 PM
  #40
FormerVendor
Flame Thrower's Avatar
i don't really know what to tell you. as soon as you go to a non-stock situation, i'm not much help. there are several other owners who have a similar modification on their truck. maybe they can help.
FT
MadMax48
03-03-2020 10:33 AM
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
Kytowboater
09-17-2015 11:17 AM
Quick Reply: What flamethrower injectors are better?
