What is this connector?
Can anyone tell me where this is supposed to go?
Driver side as u can see its between the dizzy and airbox
Doesnt look like theres any metal on the connector?
Truck is running a really low idle at warm, just changed water pump/ timing belt, idler pulley
Look for a wire lead coming from the oil sending unit....the weird ball shaped thing. If there's not one....a wire lead...there should atleast be a flat terminal to plug into.
Another possibility is if you have ADD 4wd. It could be for the actuator switch.
This does connect to the the oil sending unit, as well as something else, its like a Y. Ill have to go check when i get back to my truck.
The oil gauge is working fine as well as the temp gauge. I dont have ADD.
some drunk guy
08-03-2021 06:09 PM
mct75
08-22-2016 01:24 PM
