Water pump seized up on way home
Old 11-24-2013, 01:54 AM
Yota94ext's Avatar
So on my way home my water pump kicked it on me it's cold out so no worries about overheating as that never happened but blew my serpentine belts how big of a job is the water pump in to 3.0 L V6 3VZ-E I got a spare parts truck to use the pump off just don't know the quickest easiest way to do it as I got work Monday morning
Old 11-24-2013, 03:49 AM
Cyberman's Avatar
Water pump is driven by the timing belt. So, follow the instructions for replacing the timing belt. You WILL want to replace the belt too. Will also need new coolant, because you'll be pulling the radiator out as well.
Old 11-24-2013, 08:07 AM
Marc's Avatar
Are you sure it's the water pump?
You said serpentine belts - there's just one serpentine belt.
Does it still run?
Old 11-24-2013, 08:43 AM
Yota94ext's Avatar
We'll the drive for clutch fan seized and I'm pretty sure it's the water pump behind that and yes was just hoping it wasn't that big of job
Old 11-24-2013, 08:52 AM
HighLux's Avatar
If you have to drive it to work tomorrow...i suggest downloading a factory service manual....google "toyota factory service manual .pdf" find one thats same version of your truck.
Then hustle your butt down to autozone...get a belt, pump, coolant, etc....and get to cracking some wrenches.
Old 11-24-2013, 09:40 AM
Cyberman's Avatar
The water pump is NOT behind the fan clutch. Sounds like the pulley seized. If your water pump seized, it would overheat rather quickly. I know.
Hopefully, the year of your parts truck is close to what you drive. The fan brackets changed on the 'newer' 3.0s.
Old 11-24-2013, 02:59 PM
1993 4x4's Avatar
This sounds right. I just dealt with this not to long ago. Truck will run hot but not over heat. As long as you keep moving that is.
Here's a link to the 93 fsm. Hope it helps.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old 11-24-2013, 03:21 PM
JohnnyCanuck's Avatar
I just did mine, change timing belt, idler, thermostat, and I also changed the tensioner, mine was hydraulic, I think the 92's and earlier for 3.0 were mechanical tensioner.
Old 11-24-2013, 03:24 PM
totally a bro
Staff
vital22re's Avatar
The water pump is powered by the timing belt. If it failed truck won't run. You're more than likely refering to the idler bracket/water pump dummy bracket. The fan clutch mounts to that and the belts loop around it as well.
Old 11-24-2013, 03:50 PM
Cyberman's Avatar
You're looking to replace this:
Since this doubles as a timing belt cover, you almost have to follow part of the procedure for changing the timing belt. You may or may not be able to do this without removing the radiator, but it would help immensely.
Old 11-24-2013, 07:09 PM
That looks nothing like a water pump for a 3.0, at least not mine.
Old 11-24-2013, 07:13 PM
Cyberman's Avatar
If you've been following along, he said his fan clutch seized and broke the 'serpentine' belt. He didn't seize his water pump, but instead seized his fan bracket bearing.
Old 11-24-2013, 07:16 PM
ah, so he did.
Old 11-25-2013, 10:21 AM
Yota94ext's Avatar
That's exactly it wasn't sure before so this is just a pulley not anything internal like waterpump water pump is contained behind the circle to the right of the pulley right
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
jjrbus
07-19-2015 02:06 PM
Snort
07-19-2015 07:03 AM
Jonny246
07-12-2015 04:51 AM
Quick Reply: Water pump seized up on way home
