water pump replacement on 94 T100
Old 03-11-2014, 01:03 PM
Heather123's Avatar
is there a schematic or diagram for the proper installation anywhere online? I assume u have to pull everything by looking? was quoted 1100 by repair shop, can i do this myself easily?
Old 03-11-2014, 01:55 PM
Sturmcrow's Avatar
Assuming it is the 3VZE (V6), look for protocols on changing the timing belt. Typically you will want to change water pump and timing belt at the same time, since both are in the same place and a huge PITA to get to.
Nothing about the job is hard, except maybe getting the crank bolt off. It is very time consuming, hence the huge labor charge.
Old 03-11-2014, 02:00 PM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...09waterpum.pdf
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
Old 03-11-2014, 02:08 PM
Heather123's Avatar
THANKS! I got it figured out now, hubbys off getting new parts, guessing it wont be ready for work tomorrow... pics help a lot!
Old 03-14-2014, 10:45 AM
Turbo_4runner's Avatar
@ scope103 Thank you for the links....I'll be breaking down my 94 4runner next week hopefully!
Old 03-14-2014, 01:57 PM
totally a bro
Staff
vital22re's Avatar
To do this properly, you should replace the idler pulley and the tensioner pulley as well as the cam and crank seals.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: water pump replacement on 94 T100
