Vibration at 50mph or higher
1992 Toyota 4runner v6 3.0
Any one know what symptoms are of a u joint going out? I'm starting to get a nasty vibration around 50mph and higher .. If not a u joint what else to look for? Steering wheel does not shake and the vibrating is coming from underneath
go get the drive shaft taken off and check the ujoints for stiffness i just went thought that the vibration was in the seat and rear end the ujoint next to trans was stiff.
100% it the u joints
Had same issue. Is the any noise coming from rear end? Mines was vibrating and making noise. Turns out rear end had to be replaced. Also changed the driveshaft I had and no more vibrations.
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
