YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 03-14-2013, 08:00 AM   #1 (permalink)
Personal Sales Rating: (0)
Very rough cold start
Hey guys and gals,
Like the title states, I am having some very rough cold starts. it will wine for about 10 sec then turn over. once she is warm i have not issues, any thoughts
89 4Runner 3.0 SR5
__________________
GEN 1 lover
Luvmy89 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-14-2013, 08:02 AM   #2 (permalink)
Sound like a bad Cold Start Injector (hence the name) or Cold Start Injector Switch. What's the temperature outside when it has issues?
__________________
'91 Pickup SR5 Extra Cab- 4x4 3VZ-E 3.0L - 281k miles and counting
Gamefreakgc is offline
Old 03-14-2013, 08:04 AM   #3 (permalink)
Threadstarter [OP]
Quote:
Originally Posted by gamefreakgc View Post
sound like a bad cold start injector (hence the name) or cold start injector switch. What's the temperature outside when it has issues?
23* - 45*
__________________
GEN 1 lover
Luvmy89 is offline
Old 03-14-2013, 08:38 AM   #4 (permalink)
I don't think Luv is getting to the CSI.
If it "whines" before it turns over, the starter is spinning without engaging. Possible causes: loose starter, damaged pinion gear (on the starter itself), damaged flywheel (into which the starter engages). Can be temperature dependent at first (metal contracts with cold).
Replacing the starter is what I would recommend, because even if it is only loose you've already damaged the pinion gear. More importantly, every time you start it that way you're damaging the flywheel; once it's bad enough it is a bigger job to replace.
__________________
1994 6cyl 4wd XCab -- all stock
scope103 is offline
Old 03-14-2013, 08:39 AM   #5 (permalink)
Yeah, that would be a good place to start looking then. The purpose of the CSI is to provide extra fuel during a cold start. If it's malfunctioning, it'll have a rough time starting up. You can view some info from the FSM here on how to troubleshoot the CSI and CSIS.
http://personal.utulsa.edu/~nathan-b...ne/97colds.pdf - CSIS check with a multimeter
http://personal.utulsa.edu/~nathan-b...88coldstar.pdf - CSI check. If the switch measures ok and is not damaged, check the CSI as directed then remove it and soak the tip, not the whole thing, in gasoline overnight. Clean up the injector tip a bit (be careful not to drop or damage, it has ceramic parts that are fragile) to make sure it's not clogged up. Be sure to put a new gasket on, you might have to make your own since they are a bit hard to find. I've gotten away with re-using the crush washers since they require a fairly low torque, they are a dealer-only part.
If this doesn't fix it, next you'll need to inspect your fuel system. This means jumping terminals (forget which ones at the moment) to make sure your fuel pump is working, replacing the fuel filter, checking for leaks/damange, etc. But definitely check the CSI system first.
__________________
Old 03-14-2013, 08:44 AM   #6 (permalink)
Threadstarter [OP]
Perfect, thanks you for the diagrams I have printed them and will get on this tonight after work. thanks again.
__________________
GEN 1 lover
Luvmy89 is offline
Old 03-14-2013, 08:48 AM   #7 (permalink)
I didn't think about the starter (we posted at same time lol), it could also be your issue. I've been told that a slight tap with a hammer when you are cranking will help figure out if that's the issue. If it fires up, your starter is going bad.
__________________
Old 03-18-2013, 12:10 PM   #8 (permalink)
Threadstarter [OP]
Thank you for the advise, turns out the cold start ignition sensor was unplugged, how i do not know, but hey better that then spending 150$. thanks for the advice
__________________
GEN 1 lover
Luvmy89 is offline
Old 03-18-2013, 12:44 PM   #9 (permalink)
Gotta love the easy fix. Sometimes the connector is loose since the clasp breaks, just make sure it doesn't come off easy or use a zip tie or electrical tape to hold it on.
__________________
Old 03-18-2013, 12:48 PM   #10 (permalink)
Threadstarter [OP]
yeah wish the issue i am having with my front power windows was a simple.
__________________
GEN 1 lover
Luvmy89 is offline
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
