Vehicle Inspection?
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
There's a back-up switch/sensor on the back passenger side of the 5 speed tranny IIRC, and there is a an E brake light switch on the tube under the dash....you know the tube that the e brake bar slides into. Check those. As for the batt light, check your alt and your batt connections, clean the terminals. Might be some corrosion, there.
My back up lights didnt work, i just had a short and put new wires in. Also, in a recent 4wheel and offroad magazine, they said a good fog light cover is a toque or big sock or something easy and cheap like that. Plus when tis cold you can take them off and wear them!
***edit for spelling fail
the brake light i was told was either my proportioning valve or simply that i need to bleed my brakes properly. i have looked into the dash switch and level switch in the master cyl. before and they both work fine.
the battery light i am petty sure is a ground problem, since the alt is charging fine and my battery con. are clean as a whistle. i think if i cant figure it out right away i'll just take out the bulb in the gauge cluster for the next VI.
thanks guys.
Have you ever imagine that besides the metal detector can also be used as the security device? Now it is very common, for example before you entered into the railway station and get on the airplane, both you and your package will be checked by various kinds of device and among them the gold metal detector is really excellent as they are sensitive about metal materials since they can give out an indication when they detects them.
#27
Those chopped up weakened upper control arms will make you fail inspection no matter how much paint you put on them, so if you want to get it road worthy you're gonna have to replace them.
justdifferentials
14
06-11-2017 08:36 PM
Swampwalker
10-12-2015 09:49 AM
_Nicco_
09-21-2015 03:06 PM
