Vaccum help
Old 12-02-2007, 05:57 AM
MAXIMUS1968's Avatar
Vaccum help
I have a small canister next to the charcoal filter that has 2 vacuum lines coming from it. Cant seem to figure out where they go. 1 of them is hooked up, the other one i had to disconnect doing the head gasket job. I have a 94 22re auto, any help is appreciated
Old 12-02-2007, 06:15 AM
Elvota's Avatar
Generally... one of the lines comes from the intake manifold for vacuum. The other heads off to control what it controls.
Where is the lined that is connected... connected?
A pic might help others determines exactley which VSV you are referring to.
Old 12-02-2007, 07:33 AM
It lloks like one side goes to the cruise control and the other i have removed and cant recall where it goes. Here is a few pics
Attached Thumbnails Vaccum help-dsc00016-500-x-375-.jpg   Vaccum help-dsc00017-500-x-375-.jpg
Old 12-02-2007, 07:48 AM
Elvota's Avatar
Originally Posted by MAXIMUS1968
It looks like one side goes to the cruise control and the other i have removed and cant recall where it goes.
Others may chime in, but most of those VSV just need a vacuum source.... any source. So, if you multiple open ports on your intake, pick any one that will fit.
Of course, make sure any open ports that are left open when you are done doing what you are doing are all plugged or you'll have a vacuum leak causing problems.
Old 12-02-2007, 07:58 AM
I got one more question, The small opening on the bottom side of the intake that bolts up to lines that go around back side of head,( has 2 small bolts thats a PITA to get too) does this have a gasket/o-ring of any kind? I didnt see one in my kit, I have just bolted it up and it went together fine
Old 12-02-2007, 08:08 AM
Elvota's Avatar
Sorry... I don't have an answer for that one.
Old 12-02-2007, 08:09 AM
Here is a pic i found of what im talking about
Old 12-02-2007, 08:40 AM
Elvota's Avatar
I don't know the 4CYL motor as well, but it looks like a coolant passage to me... which would most likely require a gasket or gasket material (RTV).
What year engine?
Try this link...
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
There are a lots of exploded engine diagrams there that will show gaskets and O-rings.
Old 12-02-2007, 08:48 AM
Its the 22re, i am looking at the fsm now and i cant see that it shows one, i dont recall one there either when i took it loose. Some people are saying it needs one, I have already got the upper intake on, what a PITA if i have to take it all back off...bummer!
the_supernerd
10-01-2015 09:20 PM
87toy pickup
09-07-2015 06:42 PM
93toyoguy
08-31-2015 08:02 AM
Valvoman
06-28-2015 02:45 PM
SpeedyJ
09-06-2006 04:45 PM
Quick Reply: Vaccum help
