Using 4WD-low without front wheels locked?
No, the front wheels just won't receive power, the cv's and the d-shaft will still spin. Although, if you need 4 low for an extended period of time, it shouldn't be a big deal to have the front tires turning right? How long is "Extended" and what would you be doing?
Sponsor
i think he just ment using 2LO until 4 wheel drive is needed... i dont lock my hubs till i need them just to see how far 2wd can get me, but use 2lo for the gearing / power.
I also do it all the time...
If I need more power to pull a boat up a ramp or go up a steep hill or curb, the truck can barely get out of its own way in H2 sometimes.
I also do it if I need more control when going over said obstacles.
I seriously doubt it will hurt anything.
Originally Posted by 4Crawler
I also use 2L all the time, with dual cases, I have a true 2L gear using the front reduction box in low range and leave the rear case in 2WD. Just need to watch out and not give it too much gas, since you are applying over twice the load to the rear axle alone.
Currently the rear shifter comes out of the front recess on the center console:
Shortly I'll be installing a triple stick shifter that will bring all the shifters to the front location and there will be 3 separate, single-function sticks, Rear H-L, Front H-L, 2-4. At that point the rear shifter hole will be covered and a console could be left intact.
I was just asking if it's alright to use 4WD-Lo without the hubs locked to simulate a 2WD-Lo gear.
Originally Posted by Glenn
No, probably not. What do you mean by extended periods?
Originally Posted by junkyardblacksmith
By extended periods, I mean more than a few minutes. So far I have used this for less than 5 minutes at a time with no damage.
it's no problem. it doesn't hurt anything.
here's another thread that asked the same question:
https://www.yotatech.com/forums/f2/its-bad-drive-4l-hubs-free-62590/
I forgot about that little cup thing there. I dunno, when you get the other setup going I'd like to see. I know how useful the dual or trip cases can be.
Here is the prototype triple stick shifter:
Need to shorten the width of the shift rods in to the width of the blocks to ease installation. As is, will fit but requires lowering the t-case or raising the body for installation. Stock shifter is used up front with a new stick on each side of it for the two halves of the rear case. Totally sealed and should be as quiet as the stock shifter. In fact the shifter is so tightly sealed, will need to add venting to it (stock unit vents through the stick), that is the right angle fitting on the rear (white) shifter base).
06-01-2021 01:51 PM
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
09-22-2015 07:28 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
skoti89
07-06-2015 07:45 PM
