Truck rides crooked
Old 02-04-2015, 06:45 AM
Jake28296's Avatar
Truck rides crooked
Recently I noticed my truck is riding down the road crooked If your driving behind me you can see the drivers side door and the steering wheel is kind of cocked to the right side is it just out of alignment or is something else wrong?
89' pickup 4 inch rough country suspension 31x10.50 dick cepek fc2s 15x8 ion alloy 174 series wheels+ glenns over the rail dogbox,mega 4 tracking unit,cb and private band radio, 2 6x9 speakers and over 15 deer a year put on the back!
Old 02-04-2015, 07:03 AM
JasonYota's Avatar
Just the steering wheel off could be the front end alignment. The whole truck driving crooked could be a bent/misaligned rear axle
Old 02-04-2015, 07:13 AM
bswarm's Avatar
There's a centering pin on the leaf spring that might have sheared off. It would cause the rear axle to shift position causing a high rear thrust angle.
Old 02-04-2015, 12:12 PM
Jake28296's Avatar
the passenger rear u bolts slipped backwards. when they people did my lift they didnt tighten the U bolts well enough. The bumpstop on the spring is about 2 inches farther back from the one on the frame
Old 02-04-2015, 05:34 PM
Jake28296's Avatar
Well I thought it was that got down to go knock it loose and looked up and the spring perch has rusted completely off the frame
duckhead
07-17-2015 04:45 AM
MadMax48
07-03-2015 08:26 AM
shadowbirdie
07-01-2015 05:14 PM
miceal383
06-29-2015 12:27 AM
nrgetic99
07-23-2002 04:42 AM
Quick Reply: Truck rides crooked
