Tranny and Transfer case
I have a 1988 toyota 4runner. Does the transmission and transfer case share the same gear oil? Or are they both separate units?
and if the seal goes bad, all the transmission oil gets pumped into the t-case and leaks everywhere from out of the shifter hole, and the input shaft bearing on the w56 takes a poo, and leaves u stranded on the side of the interstate. but the good news u can drive 10 mph down the side of the road and make it to the shop to replace the transmission on a holiday weekend... Ask me how i know...
they dont share the same fluid. These use the same fluid. Separate "containers".
http://www.ncttora.com/fsm/index.html
go here and scroll down to your vehicle and download
and if the seal goes bad, all the transmission oil gets pumped into the t-case and leaks everywhere from out of the shifter hole, and the input shaft bearing on the w56 takes a poo, and leaves u stranded on the side of the interstate. but the good news u can drive 10 miles per hour down the side of the road and make it to the shop to replace the transmission on a holiday weekend... Ask me how i know...
Bourbonblues
12-15-2017 05:43 PM
justdifferentials
14
06-11-2017 08:36 PM
