tail light problems
Old 02-18-2009, 07:55 PM
Ezrider_92356's Avatar
tail light problems
well i kept blowing tail light fues i took my tail light assmebly apart trying to find the probelm today, the problem was comming from the pasnger side rear light there is a little black box that is half melted so i took it apart and it there where some peices on a circut bord that where compleetly burned out and some that wernt even conected anymore looked like a couple dioeds and a couple resistors maby not sure. anywhaz what is this little black box and where can i get another
Old 02-18-2009, 07:59 PM
abecedarian's Avatar
probably a taillight converter for towing trailers which have combined brake/turn signal lights.
Old 02-19-2009, 06:09 AM
desertcox05's Avatar
+2 on converter box
Old 02-19-2009, 10:44 AM
that was kinda my thought to, question is there one box on each side or just one, where can i get another? also i removed all the loose outta the box and wraped it with e-tape and now im not blowing fuses but i only have 1 tail light blinkers on both sides and no break lights.
Old 02-19-2009, 10:50 AM
most autoparts stores should have it in their trailer section.
depending on the type, it could wire: tap into the left and right signals, running lights and one of the brake lights and ground, then output left/brake, right/brake, running light and a ground, IIRC. The running light wiring may not be part of what you have.
Old 02-19-2009, 10:21 PM
can this box affect the tail lights of the vehical itself or do i still have other issues becouse i still have no break lights and no passenger side tail light
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: tail light problems
