Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (1)
Swaping harness
#2 (permalink) |
Personal
Sales Rating: (1)
[OP]
included pictures
I have a few pictures of the harnest I want to swap, but know I am trying to figure out the best way to not use the dash wiring part, since that works great in my 1986 truck, I think all I need is the air flow meter connector and the coil connections, and with the engine harness, I will wire in the temp sensors to the dash, and I will have to connect the safty switch on the automatic, so it will start. Here is a few picturs:
#3 (permalink) |
Personal
Sales Rating: (1)
[OP]
I cant bilieve nobody has a good thread for this, or any information about using a automatic harness!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!i thought this forum was for toyota pickups!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#4 (permalink) |
Personal
Sales Rating: (1)
[OP]
Lame
LAMELame lame
#5 (permalink) |
Personal
Sales Rating: (0)
Man I hope you took lots of pictures because I don't see no labels on those connectors!
and those pictures are pretty confusing, not helped by the text overlay. That last picture definatly has the inst' cluster connections, two white and a blue at the lower right. Where are the two rats nests of spliced wires, off screen or under the text? Are all these of the 4x4 A/T harness? Assuming all the hacked together wires are all for the AFM or ignition, yes deloom them. Stuff it into a new looming cover and rerap. I'd like to point out i said "If you found the correct harness. I'd swap it in instead of trying to fix the mess.". Also remeber I said you had posssible power supply problems to your ECU, eg swapping in new wires for the AFM isn't going to solve the problem. And you can't use the A/T 4x4 ecu, it'll bitch about the tranny not being there like I said before. You'll need that other ecu you mentioned in PM, and the wires to the AFM from the 4x4 harness. Just take your time and work thru it, if it pisses you off take a break. Don't cut open the looming you need to unrap it so as not to damage wires with a stray cut.
__________________
#6 (permalink) |
Personal
Sales Rating: (1)
[OP]
Shoot, I just choped the wiring harness out of my truck, I thought people have used the automatic harness for a manual truck? Looks like I will have to look for a 2wd harness?? I will have to call yota yard?
#7 (permalink) |
Personal
Sales Rating: (0)
To the OP:
You really ought to stick with a harness as close to your year as possible. 1989 is a different year (for trucks) and could encompass different lengths between "branches" to fit around the curves and corners underneath the dash. Also, Toyota had a bad knack for changing connectors... sometimes randomly. In fact, 1989 is kind of a bad year to source. There were a lot of stupid, little changes halfway through the model year.
__________________
Download your Factory Service manual HERE! I just finished BUILDING my own 4Runner because I'm too cheap to buy one... go ahead and call me crazy! PROJECT FRANKENYOTA: Stolen and parted out. I bought the body to build my own. Then it was stolen and parted out again... so I rebuilt it again. Datsun 240z: For when the day comes that my 4Runner is "done". |
#8 (permalink) |
Personal
Sales Rating: (1)
[OP]
I am going to call yota yard and see if they can find me a whole wiring harness with ECU for a 1986 2wd pickup.
#9 (permalink) |
Personal
Sales Rating: (0)
I thought you had an 89 motor, 1989 22re swaped into an 1986 22r, yes? You might have issues with connectors being of different types using an 86, eg they will/might not mate up to some of your sensors.
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
Hmm... thats partially my bad I s'pose. I wasn't aware of the 89 engine. The connectors will most likely be different (throttle position sensor and fuel injector connectors come to mind..)
__________________
#11 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
94 SR5 2wd PU Extra Cab 3vze 5SPD Bone Stock Clean 50 Ford Shoebox V8 Flatty/Slow Coming I BUILT MY BUSINESS!! |
