Starter going bad?
Old 05-05-2008, 01:40 PM
wowza025's Avatar
Starter going bad?
When I try to start my truck when its hasnt been run for a while, the starter just spins. Luckily my driveway is slanted, so I can easily roll start it, and it starts right up. After the truck has been run for a couple minutes, the starter will engage again and start the truck right away. Whats the deal?
Old 05-05-2008, 01:49 PM
MMA_Alex's Avatar
check the batt terminals. I had the same issue, and it was that the terminals were severely corroded (didnt look like it till i took em off) and that caused a reduced current causing the starter not to spin fast enough to spin out, and engage the flywheel
Old 05-05-2008, 01:54 PM
wowza025's Avatar
Thanks for the quick reply....I'll go check them and see whats up
Old 05-05-2008, 06:07 PM
Noltz's Avatar
If this is on your 3.0, and your valve covers are leaking, it's possible that oil has collected in the bendix of the starter, preventing positive engagement. You may need to remove and clean your starter. And if you're into that, strongly recommend to install new contacts at the same time. ~$15 at the dealer.
Old 05-05-2008, 07:59 PM
wowza025's Avatar
shoulda specified...22re, and i cleaned my terminals and she started right up....but i noticed there is a crack in my positive terminal...haveta pick up a new set thanks for the tip
Old 05-05-2008, 09:19 PM
Jay351's Avatar
when you say "the starter just spins" Do you mean that the engine will just turn over, or the starter will just spin by itself without moving the engine?
If its the first - Something is wrong with your engine/charging system
If its the latter - chipped flywheel.
Old 05-05-2008, 09:25 PM
abecedarian's Avatar
Or something wrong in the starter keeping the pinion from engaging the flywheel.
Old 05-05-2008, 09:46 PM
Jay351's Avatar
Good point.
boguspiano
12-17-2015 02:51 AM
tdsmith8
08-11-2015 10:09 AM
clok
08-01-2015 09:42 PM
ZONAYODA
07-13-2015 07:17 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Starter going bad?
