Solid Copper HG
Old 05-06-2011, 03:24 PM
Outsane's Avatar
Solid Copper HG
Some one try these out..
http://www.scegaskets.com/Toyota/22R.../tc257553-1-2/
my HG is fine or I would, there always seems to be atleast 3 blown Head gaskets in here
Posted in here because there are 4 times as many viewers then the 84-85..can we just merge the two already? Half of the 86+ are sas'd any how.
Old 05-06-2011, 04:34 PM
MudHippy's Avatar
20R/22R/RE/RET use the same head gasket, I'm pretty sure. So it's relevant.
Those are interesting. Did you know LCE sells MLS HGs for them too? http://www.lceperformance.com/MLS-He...-p/1024012.htm
Old 05-06-2011, 07:17 PM
yotarover's Avatar
so which hg do you use with a block that's been decked & new head? 22re last one i used was the stock thickness felpro
Old 05-06-2011, 08:42 PM
MudHippy's Avatar
You'd have to know how much was taken off. They make different thickness HGs to take up the difference. Shouldn't really matter too much though since the head was new. It's not going to raise the compression ration a whole lot. You might want to use a thicker one if you ever resurface the head.
Old 05-07-2011, 08:08 AM
yotarover's Avatar
thanks for the info. i just handed over the block and told him bore and deck it. now im stuck trying to figure out weither to keep building. or go the fast route and drop in a rebuilt for 800$ (guy uses enginetech kits)
Old 05-07-2011, 02:23 PM
Zelephant's Avatar
Cool, MHGs for the 22RE! I've seen them for 7mge's, but not for the 4. Thanks for posting!
In all honesty, though, the 3VZE guys need this worse than we do.
Old 05-07-2011, 04:49 PM
shaeff's Avatar
Cometic makes a MLS MHG for the 22re.
Also- with a copper gasket, I believe you're going to have to go with o-rings.
ashamsuddin
17
01-13-2023 03:17 AM
TheBFA
02-15-2020 06:55 AM
83yotastockR
11
11-10-2015 06:54 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
noahstancik
09-10-2015 10:47 AM
Quick Reply: Solid Copper HG
