shock help
Old 08-15-2007, 10:20 AM
bull307's Avatar
shock help
Hey ive searched the forums for an answer to these questions but i cant find any
i just bought some sky jacker shocks and when i got them they wernt all springy like i thought they whould be. instead i can compress them and strech them out with my bare hands. is it suppossed to be like this? and also what is a good way to fit the new bushings through the holes in the rear shocks? that job is a pain in the butt
Old 08-15-2007, 10:25 AM
MMA_Alex's Avatar
theyre not supposed to spring out. they should however offer resistance to your pushing. the more resistance the stiffer the shocks.
I just did my fronts last week and after 94k miles the shocks were pretty worn out, and didnt offer a whole lot of resistance, especially compared to the stiff rancho 5000's i replaced em with.
Old 08-15-2007, 10:30 AM
bull307's Avatar
wel to be more specific about the shocks they are ment for a 3 to 4 inch lift
but how is it supposed to hold the wieght of my car like this with no real resistance
Old 08-15-2007, 10:36 AM
ewong's Avatar
Monotube shocks will "spring out".
Most twin tube do not
Oh - shock absorbers dont "absorb shock" - the British term is much better - DAMPER
Shocks "dampen" the oscillation (aka "boing") of the springs
Jay351's Avatar
the shocks do not hold the weight of your car, springs do.
torsion bars up front and rear leaf springs provide the support, without the shocks your truck would be like a bucking bronco.
If these shocks are ment for a 3-4" lift are you sure they will work for your application?
Do you have any lift?
Old 08-15-2007, 10:55 AM
bull307's Avatar
its in the mail
Old 08-15-2007, 10:57 AM
4Crawler's Avatar
Gas pressure shocks will "spring out" but plain old hydraulic shocks will not. For example my old KYB Gas-A-Just shocks would fully extend with no weight on them. My current Rancho (5000 and now 9000) shocks are simple hydraulic shocks and they do not extend by themselves. A plain old shock is just a tube full of oil with a piston inside and all they do is damped oscillations. A gas filled shock has an internal reservoir that holds gas under pressure to reduce foaming in the oil during high speed use. That gas expands and forces the shock rod out with no load on the shock.
Old 08-15-2007, 01:46 PM
bull307's Avatar
well that clears it all up thanks for the help
now does anybody know where i can get something like coil springs for the back of my truck so it doesnt sag?
Old 08-15-2007, 01:49 PM
4Crawler's Avatar
Try these:
- http://www.4x4wire.com/forums/showfl...5&o=31&fpart=1
- http://www.gearinstalls.com/dc.htm
Old 08-15-2007, 02:06 PM
TORTIS's Avatar
you can have your springs re-arched at a spring shop. it cost me $175.00, but that was 10-12 years ago.
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: shock help
