Shifting problems
Old 03-03-2013, 11:02 AM
Ringalls523's Avatar
Shifting problems
I got stuck the other day and ever since my truck has been close to impossible to put into gear. With the clutch to the floor if I try to put it in gear it makes a slight grind and I have to force it. Just replaced the slave cylinder and it didn't seem to help. Any ideas anyone?
Old 03-03-2013, 11:47 AM
NorthIdahoyota's Avatar
Can you have someone watch the clutch fork while you push the pedal? Is the master cyl still full?I don't know enough about the guts of the tranny itself
Old 03-03-2013, 01:16 PM
DJ99's Avatar
Check to see if your clutch pedal bracket isn't cracked or broken.
Old 03-05-2013, 07:11 PM
Got it all figured out, thanks for the ideas
Old 03-05-2013, 07:54 PM
Co_94_PU's Avatar
Somebody moved your seat back on you?
Old 03-05-2013, 07:57 PM
My seat stays all the way back. I'm 6'1" and drive a single cab
Old 03-05-2013, 08:18 PM
Co_94_PU's Avatar
Sorry, subtle hinting failed. What was the problem, for whoever shows up later asking the same stuff
Old 03-05-2013, 08:29 PM
Grego92's Avatar
Were you pushing in the brake pedal thinking it was the clutch pedal?
No lie, that was the problem I came across when I saw this girl stressing out in the campus parking lot many many years ago. She was nearly starting to cry because she was going to be late for a new job she had just started. I asked if I could help, got into her 240sx (or something like that) and started it right up!
Old 03-05-2013, 08:39 PM
The guy that sold it to me had a new clutch put in, whoever did it didn't tighten the bell housing bolts and the bottom ones eventually fell out causing the tranny to separate a little bit. All better now
Liadrin
04-25-2022 02:54 PM
Liadrin
09-01-2015 06:44 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Shifting problems
