| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
seafoam treatment question
#2 (permalink) |
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Preping for SAS...... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#3 (permalink) |
Thanks, EWAYota, did a search but didn't find that big thread!
#4 (permalink) |
I would read the 2nd link above before doing any treatment...........
#5 (permalink) |
the thread my bamachem has LOTS of good information. ill be doing mine again tonight through the pcv
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#6 (permalink) |
I just did the Seafoam to my 98 4Runner, the oil treatment just follow the directions on the can, but as far as doing the carbon treatment through the vacume line, i used one that was on the intake or plenum? But be very careful you dont pour the whole thing in at once or put the hose in to suck it out, just dribble it in, Cuz if you do, liquid does not compress and you well blow a rod through your block. And the other thing is after i was done letting it sit for ten minutes then starting the engine white smoke pours out and when you drive it, it will be twice as bad for about 4-5 miles blowing all the carbon out. And fiinally my experiance after all said and done when i got on the gas it the engine pinged a bit had me worried but it went away and shes runnin good. So hope this helped a bit. Cheers
__________________
98 4Runner Limited |
#7 (permalink) |
on the carbon treatment i used a .25 can
__________________
#8 (permalink) |
Closest vacuum line behind throttle plate. You don't want to get it on the airbox side of the throttle plate because there's not very much vacuum at idle.. Closest port on intake manifold side of throttle plate ensures adequate vacuum to suck the crap up and is far enough upstream in the plenum to distribute it to the whole intake and ports associated with each cylinder.
__________________
1992 Toyota 4x4 Pickup - 22RE, full 2.25" exhaust, 31x10.50x15 Remington Mud Brutes. Feels like a fun little golf cart after I get out of my lifted 2000 F250 Superduty, but dang it's fun to drive and the gas mileage is nice. |
#9 (permalink) |
I used the charcoal cannister purge line when I did mine. Smaller line made it easier to regulate the flow and it is up front, easy to reach and long enough to use. I adjusted flow by dipping the end of the vacuum line in and out of the Seafoam in the bottle.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| seafoam question | mkgarrison5 | 95.5-2004 Tacomas & 96-2002 4Runners | 36 | 04-09-2007 06:05 PM |
| PCV location/Seafoam treatment on a Lexus? | LSUMatt1514 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 02-27-2007 08:39 AM |
| high mileage Seafoam treatment? | co4rnr | 86-95 Trucks & 4Runners | 12 | 02-26-2007 06:55 PM |
| Seafoam Question | igogusto | Newbie Tech Section | 6 | 09-15-2006 09:24 PM |
| CEL & VSC\TRAC Lights after Seafoam Treatment on 03' | kaneman23 | 03+ 4Runner/GX470, & 05+ Tacomas | 7 | 09-04-2006 08:38 PM |
