sas shackel angle help
taced up my hanger then drilled the wholes for the frame tubes a little bit foward from center under the body mount
it looked like the shackles with no weight had about -10* so i figured with weight it would have about 15*. nope way to much, my hanger is flush originally had it 3/4 foward, if i move it back to 3/4 foward would it make a big impact on the shackle angle?
this is what it looks like with weight(kinda hard to see)
and no weight
and no weight
"angle" is just a rule of thumb the angle itself doesnt mean Jack. To get the most of a leaf spring pack you need a shackle that will let it fully drop and fully compress to "flat"... ie no inversion. Then place the shackle hanging point at the optimum distance from the forward spring hanger.
Your springs under weight of your front end are nearly flat which is fine. You could actually move your front hangar further back 1/2". A nice vertical shackle at full droop is ideal. But I'd leave it. A little forward swing of the shackle is fine
live4soccer7
05-11-2016 06:52 PM
hiluxinargentina
09-30-2015 05:51 PM
Toys4parts
09-26-2015 01:56 PM
