Replacing CV joints, DIY or no?
Old 08-01-2009, 07:53 AM
  #41
toyospearo's Avatar
see if this helps=
https://www.yotatech.com/forums/f116...ctures-158106/
Old 08-01-2009, 08:04 AM
  #42
Lumpy's Avatar
Originally Posted by toyospearo
Thank you, I'll keep this bookmarked for when I need to do this to my truck. The 4runner has ADD and I just found this. It didn't look like the end cover came off the hub cover but alas it does!!!
I could not get to this I didn't want to put a hole in it if it didn't come off now I know it does.
https://www.yotatech.com/forums/f2/c...en-help-33590/
https://www.yotatech.com/~corey/tech.../matt_hubs.htm
Old 08-01-2009, 08:06 AM
  #43
tc
tc's Avatar
Yes, the rounded dust cover has to come off, then there's another 12mm bolt threaded into the end of the CV.
Take the splined plate off, then there's a circlip around the CV axle.
Old 08-01-2009, 08:10 AM
  #44
Lumpy's Avatar
I had a screwdriver in there trying to pop if off but it just seemed like it was all one piece. Well I'm off to knock the darn thingy and have at it! Thanks guys!!!
Old 10-21-2012, 09:58 PM
  #45
jasonmenger's Avatar
I have to do the same exact thing for my truck!
Old 10-22-2012, 06:57 PM
  #46
What is the best replacement half shaft?
Old 10-22-2012, 07:17 PM
  #47
aa1911's Avatar
1sttoyotaparts.com, buy their reman CV axle assemblies; will only take you a few minutes to do each side and they're only $120, hard to beat for OEM quality.
I just did mine on my taco, very easy and didn't have to mess with the axle assemblies themselves, just ripped out the old for cores and threw the new ones in, good to go.
highly recommend doing both sides also, if one is bad, you can bet that the other is not far behind!
Old 10-22-2012, 07:30 PM
  #48
I might be looking in the wrong place but I just looked at that website and the cheapest I could find was close to 300 dollars I was looking at the napa ones I haven't read many bad review about them and does anyone have any detailed links to a cv replacement I have a general understand of it I just want to see all of the washers and lock ring inside the hub before I start
Old 10-22-2012, 07:41 PM
  #49
aa1911's Avatar
you're looking at the new ones, they're almost $400. find the remanufactured ones, much cheaper.
looks like they went up to $150 but still a good deal. not sure what year you got there.
I was a bit confused on the washers and retainer clip until I saw the new CV's, they had all of the new hardware on them already, nothing to transfer over thankfully. Literally just yoinked out the old, in with the new, took longer to jack up the vehicle and get the steering knuckle/brakes outta the way. Use a pry bar to yoink 'em out, rubber mallet will tap 'em back in place and button her back up.
Old 10-22-2012, 09:16 PM
  #50
It's a 94 and thank you very much this was very helpful I appreciate it a lot
Old 10-23-2012, 09:48 AM
  #51
aa1911's Avatar
lots of folks willing to help out here on YT, just ask if ya get stuck! I'm no mechanic but I did stay at a Holiday Inn last night...
good luck, hope you get fixed up quick
nick9455649
09-11-2015 05:10 PM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
crashburnoveride
07-10-2015 06:39 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: Replacing CV joints, DIY or no?
