relocating stereo
Old 01-07-2009, 05:27 PM
Windsor's Avatar
relocating stereo
Has anyone relocated their stereo higher in the dash, to where the ash tray and lighter are?
I'm thinking if I got the stereo up higher, it would be easier to manage it while on the road and I could do something "better" with the center console area.
Old 01-07-2009, 05:36 PM
abecedarian's Avatar
I've got an 88 4Runner and put my ashes out through the vent/wing window: I'm trying to make sure my carbon is sequestered directly into the ground.
Old 01-07-2009, 06:00 PM
Tubbyfatty's Avatar
Get a remote for the stereo, or buy a stereo with a remote. Both my new and old pioneer decks have remotes.
Old 01-07-2009, 06:01 PM
littlecommando's Avatar
sounds like a good idea, but also sounds like alot of work
Old 01-07-2009, 06:10 PM
on the <89 trucks and <90 4Runners... there's just about no where to put the stereo other than in the stock location, under the arm-rest between the front seats (if you're lucky enough to have front buckets) or in the glove box.
Old 01-07-2009, 06:23 PM
Windsor's Avatar
I have looked into that, and it looks like I might be able to get one (Alpine CDM-9823 came with the 4Runner).
Still, no cupholders drives me bonkers.
Old 01-07-2009, 08:39 PM
Tubbyfatty's Avatar
Wow no cup holders? That really sucks.
Old 01-08-2009, 07:38 AM
space-junk's Avatar
id rather have no cupholders than ones that cover up my hvac controls...
to the op, go to crutchfields or your local stereo shop and they should be able to add an aftermarket remote as long as your cd player will accept one...
Old 01-08-2009, 08:01 AM
Windsor's Avatar
Well, the HVAC controls are up high enough that there is no way a console-based cupholder is going to get in the way.
I guess the question is more along the lines of "how much junk is behind the ash tray that would block a stereo install up there?"
Old 01-08-2009, 11:58 AM
annoyingrob's Avatar
My brother used to own a 71 Volvo 140, which really had no proper spot for mounting a modern stereo system, so I installed the head unit under the seat, then he made a bracket that fit under the dash where we installed the face-plate. The faceplate could be flipped up out of the way, completely stealth, or you could flip it down to operate the radio. Flip a small switch beside the faceplate, and the CD came out between your legs. It was an awesome setup.
Some cat5 cable, and you can connect the faceplate and the head unit together.
Old 01-08-2009, 12:12 PM
http://www.jcwhitney.com/autoparts/P...erhead+console
hmmm...
theking11863
03-19-2016 09:36 PM
sphealy
09-03-2015 07:55 PM
bobpat
08-01-2015 09:25 PM
Esibnitsud
07-30-2015 08:19 PM
Quick Reply: relocating stereo
