rebulding 22r problems
Ok about two months ago my timing chain ate through the cover. After pulling the head and timing chain cover i decided to pull the block and replace the bearings. So i ordered new bearings and installed them everything looked fine.
So after reinstalling the engine my thrust washers stacked up and ruined my crank. Bought a refurbished crank that had been ground .10 and new bearings. Reinstalled the engine and it turned over fine. couple squirts of carb cleaner and its started but wasn't getting fuel. While diagnosing the fuel problem the engine started to turn slower and lockup. Now it turns then stops bump the starter and it will turn over 360 then stop again. I checked my grounds and pulled the plugs which made it turn quicker. But with the plugs back in it it stops every 360.
So just wanted to see if you guys had any ideas thanks abunch.
Thomas
Thomas
Staff
With the plugs out, I would turn it by hand with a socket. I would not use the starter and try to locate the bind that way. I too would suspect the bottom end like journal, other areas I would check would be timing chain, something in the head and if all that checked out, would start looking at the clutch or tranny and see if there is an issue there.
If it is doing it at a full 360 degree, it does sound like it is in the motor. Are you sure your starter isn't causing any issues?
I made sure not to mix anything up and i did plastigauge don't remember the exact numbers but they were in spec. The starter seems fine and i just installed the clutch in may. I will go check with a socket when i get the chance.
Thanks.
Thanks.
After rechecking my rings and bearings i found when i torque connecting rod no.2 it locks everything up. So is there any way for me to check if my rod is out of round?
Thanks
Thanks
Cap is on the way i took it off may try reversing just in case tough. Plastigage shows within spec. Is there anyway to check if the rods out of round at home?
Your help is much appreciated.
