rear window pickup removal
Old Jul 2, 2008 | 11:59 AM
cunninglinguist's Avatar
Hey guys. I'm going to be switching from a solid window to a slider window for my 86 pickup. This will be my first solid window that I've ever removed. I have the fsm for instructions but I'm looking for any tips that would be helpful so I won't break anything taking it off and putting it on. I've searched and couldn't find much.
thanks
Old Jul 2, 2008 | 12:52 PM
crews462's Avatar
my bad, even monkey's fall out of trees.
Old Jul 2, 2008 | 12:57 PM
mrtejman's Avatar
I just popped mine out with a screwdriver, no sweat
Old Jul 2, 2008 | 01:22 PM
Flash319's Avatar
Why do people give advice when they do not know what they are talking about crews462????? Just pop it out with a screw driver and you hand. Very easy. Don't cut the gasket like crew said.
Old Jul 2, 2008 | 01:24 PM
SwampThing's Avatar
Old Jul 2, 2008 | 10:22 PM
Robert m's Avatar
its not hard at all. i did the opposite of you (slider to solid) and used the FSM and had it done in less then and hour. only trouble i had was at the bottom corners. i had to use a flathead screwdriver to carefully pry the gasket up enough to pull the rope past the bend. after that it went real quick. also make sure you have a buddy to help hold the window up on the outside while you work the inside.
voiddweller
19
May 2, 2016 09:10 PM
markshoreline
Jul 20, 2002 01:00 PM
Corey
Jun 19, 2002 11:06 AM
